Hàn Quốc [Tình Cảm | Hài Hước] Petty Romance 2010 720p HDTV x264 AC3-OHE
Thảo luận trong 'HD Zone' bắt đầu bởi relex_thu7, 16/1/15.
  1. relex_thu7
    relex_thu7 New Member
    [​IMG]​
    Trích dẫn:Format : Matroska
    File size : 2.77 GiB
    Duration : 1h 57mn
    Overall bit rate : 3 381 Kbps
    Encoded date : UTC 2011-01-27 10:10:44
    Writing application : mkvmerge v4.4.0 ('Die Wiederkehr') built on Oct 31 2010 21:52:48
    Writing library : libebml v1.0.0 + libmatroska v1.0.0
    Video
    Format : AVC
    Format/Info : Advanced Video Codec
    Format profile : [email protected]
    Format settings, CABAC : Yes
    Format settings, ReFrames : 5 frames
    Codec ID : V_MPEG4/ISO/AVC
    Duration : 1h 57mn
    Bit rate : 3 000 Kbps
    Width : 1 280 pixels
    Height : 544 pixels
    Display aspect ratio : 2.35:1
    Frame rate : 23.976 fps
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8 bits
    Scan type : Progressive
    Bits/(Pixel*Frame) : 0.180
    Stream size : 2.40 GiB (87%)
    Writing library : x264 core 112 r1867 22bfd31
    Encoding settings : cabac=1 / ref=5 / deblock=1:0:0 / analyse=0x3:0x113 / me=umh / subme=8 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=6 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc_lookahead=50 / rc=abr / mbtree=1 / bitrate=3000 / ratetol=1.0 / qcomp=0.60 / qpmin=0 / qpmax=51 / qpstep=4 / ip_ratio=1.40 / aq=1:1.00
    Language : English
    Audio
    Format : AC-3
    Format/Info : Audio Coding 3
    Mode extension : CM (complete main)
    Codec ID : A_AC3
    Duration : 1h 57mn
    Bit rate mode : Constant
    Bit rate : 384 Kbps
    Channel(s) : 2 channels
    Channel positions : Front: L R
    Sampling rate : 48.0 KHz
    Bit depth : 16 bits
    Compression mode : Lossy
    Delay relative to video : 16ms
    Stream size : 322 MiB (11%)
    Language : Korean
    Trích dẫn:Jung Bae, một họa sĩ vẽ truyện tranh quyết định tìm kiếm một người viết truyện chuyên nghiệp để tham gia cuộc thi truyện tranh “người lớn” có giải thưởng lên đến 130 triệu won. Da Rim, một biên dịch viên cho tạp chí người lớn vừa bị sa thải vì “trí tưởng tượng quá phong phú” của cô đã gây ra không biết bao nhiêu là hậu quả. Bị lóa mắt với số tiền thưởng khổng lồ, cô đồng ý hợp tác với Jung Bae cho cuộc thi "truyện tranh người lớn".
    Bộ phim Petty Romance là câu chuyện tình yêu đầy hài hước đi từ tưởng tượng đến thực tế giữa anh họa sĩ vẽ “truyện người lớn” và một cô gái chuyên viết về đề tài giới tính. Đây là tác phẩm nhận được rất nhiều sự quan tâm chú ý của giới điện ảnh Hàn Quốc với kịch bản thú vị kể về quá trình viết nên một câu chuyện dành cho người lớn.
    2 Parts 1Gb + 1 Part 790.78Mb
    http://up.4share.vn/d/7b4a4e4a4a494a4a
