Import Sony DCR-HC40 Mini DV to AIC MOV or H.264 MOV on Mac for iMovie
Thảo luận trong 'Phần mềm' bắt đầu bởi tungnv22, 18/1/15.
  1. tungnv22
    tungnv22 New Member
    I have a Sony DCR-HC40 handycam, is there any hope of it working with iMovie -- or any other Mac application for that matter? Neither my iMac or MacBook Pro can even play the recordings? Sony has no software that I can find on their site that helps.
    Now Just Follow This Step to Import Your DV Videos from Sony DCR-HC40 to iMovie
    First, please open your iMovie. Then Click File > Import to the DV videos from Sony DCR-HC40 you want to load to iMovie, after that, just click Open.
    If your screen still stays blue, maybe the video can't be accepted by iMovie. iMovie supports the most popular video formats including DV-Standard, AVCHD, MPEG-2, HDV (High Definition Video), QuickTime Movie(including mov, m4v, mp4), iSight, MEPG-4 etc. If you still face problem importing Sony DCR-HC40 DV footage to iMovie for editing and creating your movie, you can use Aunsoft Video Covnerter for Mac as the best Sony DCR-HC40 DV to iMovie MOV converter. With the DV to AIC MOV converter, you can keep the highest video quality for editing. Since Apple Intermediate Codec is less compressed format, the output video size will be larger than the original file.
    Follow the guide below and you will find it easy to edit videos from Sony DCR-HC40 Mini DV camera on Mac OS X.
    Step 1. Upload Sony DCR-HC40 DV files to Aunsoft Video Converter for Mac.
    Connect Sony DCR-HC40 to Apple iMac/MacBook Pro via USB 2.0 cable, run Aunsoft Video Converter for Mac as the best 2011 Sony DV to iMovie AIC MOV converter. Click the "Add" button to browse and import the .DV files from Sony DCR-HC40 camera to Mac application.
    Step 2. Choose AIC codec MOV as output format.
    Click the "Format" option, and move mouse cursor to QuickTime Movie Format > Apple InterMediate Codec(AIC) (*.mov) as output format. You can click the "Settings" button to adjust the video/audio parameters for iMovie.
    Step 3. Convert Sony DCR-HC40 DV to MOV with AIC for iMovie 8/9/11.
    Click the convert button under the preview window, the Mac Sony DCR-HC40 DV converter will start the Sony DCR-HC40 DV to iMovie conversion in high quality.
    Tip: The Sony DCR-HC40 has 1/5 inch Advanced HAD™ (Hole Accumulation Diode) CCD with 690K effective pixels, an unimpressive 10x optical zoom, and a focal length of 3.2 - 32mm. The HAD™ CCD has been designed to reduce video signal noise, which means that the consumer gets better image quality with less fuzz. In addition, Sony DCR-HC40 provides video recordings with DV format stored on mini DV.
