MAGIX Movie Edit Pro 17 Plus HD 10.0.10.2 + Content Pack (14.03.2011)
Thảo luận trong 'Phần mềm' bắt đầu bởi tungbop, 17/1/15.
  1. tungbop
    tungbop New Member
    MAGIX Movie Edit Pro 17 Plus HD 10.0.10.2 + Content Pack (14.03.2011) | 3.76 GB
    MAGIX Movie Edit Pro 17 Plus is the world's first 3D video editing program. Edit your videos as usual in 2D, create breathtaking 3D movies that captivate your audience, and experience the 4th dimension of video editing: speed! With the fastest MAGIX Movie Edit Pro of all time, you will get perfect results in a flash. Only MAGIX Movie Edit Pro 17 Plus offers the unique combination of powerful editing tools, professional effects templates, extensive audio dubbing and individual customization options.
    Transform your best video recordings into exciting theater-quality films in a flash with MAGIX Movie Edit Pro 17, including background music, animated transitions, captions, and cinema-quality effects! Simply import your video material into your PC, cut and edit it however you like, and then burn it directly to disc - including professionally animated menus for DVDs and Blu-ray discs.
    Modern functions such as MultiCam editing for multiple cameras, sensational secondary color correction and a completely reworked, professional DVD and Blu-ray authoring make MAGIX Movie Edit Pro 17 Plus the best Movie Edit Pro to date.
    - More than 1000 special effects, cinematic transitions and templates included
    - Advanced audio dubbing: Dolby®Digital 5.1 Mixer and much more
    - Full HD support: for HDV and AVCHD camcorders
    - 99 tracks, MultiCam editing, travel route animation, and much more
    - Present your videos on TV, on the go or online
    More than 50 new features:
    - Improved performance during video editing
    - Faster loading times for video projects
    - Upload videos directly to Facebook
    - AVCHD import assistant with preview function
    - Redesigned user interface in modern design
    - Redesigned export assistant with clear selection
    - Video monitor zoom and tracker outside the monitor window
    - Effects masks: Apply video effects to selected areas
    - Optimized memory usage on 64-bit systems
    - and much more...
    NEW! Stereo3D:
    - World premiere! Full Stereo3D workflow
    - Full import functions for many 3D camera models
    - Editing of own 3D recordings made, for example, with two cameras
    - Real 3D fades and titles for your 3D video projects
    - Preview and output to all conventional 3D display devices
    - Output in all formats (DVD, Blu-ray Disc, file, YouTube, etc.)
    Supported import formats:
    Video: AVI, DV-AVI, MPEG-1, MPEG-2, MPEG-4, MTS, M2TS, MXV, MJPEG, QuickTime, WMV(HD), MKV
    Audio: WAV, MP3, OGG, WMA, MIDI, DolbyDigital Stereo, DolbyDigital 5.1
    Images: JPEG, BMP, GIF, TIF, TGA (supports scanners and digital photo cameras [TWAIN])
    Supported export formats.
    Video: AVI, DV-AVI, MJPEG, MPEG-1, MPEG-2, MPEG-4, QuickTime, WMV(HD)
    Audio: WAV, MP3, DolbyDigital Stereo, DolbyDigital 5.1
    Images: JPEG, BMP
    Supported file extensions (import): .avi, .dat, .evo, .m2v, .m1v, .h264, .mpv, .mpg, .mpeg, .mpg2, .mps, .mp2, .mpe, .m2s, .vdr, .vob, .mod, .vro, .ts, .trp, .tp, .m2t, .mpt, .mmv, .m2ts, .mts, .tod, .mov, .mp4, .dvr-ms, .asf, .pva, .mp4, .mpeg4, .mpeg-4, .m4v, .3gp, .3g2
    Supported devices:
    - IEEE1394/FireWire/DV/i.Link interface for use with DV/HDV camcorders
    - USB camcorder (DVD/hard disk/memory card) and webcams
    - VfW or DirectShow-compatible video, TV or graphics cards with video input
    - WDM-compatible TV tuner cards, DirectX9 and BDA driver compatible DVB T/S tuner cards
    - Blu-ray, DVD-R/RW, DVD+R/RW, DVD RAM, or CD-R/RW burners
    System requirements
    - Microsoft Windows XP, Vista, 7
    Minimum system requirements:
    - Intel Core Duo with 1.83 GHz, AMD Dual-Core with 2.0 GHz
    - 1 GB RAM
    - 1 GB hard disk memory for program installation
    - Multi-channel sound card recommended for Surround sound editing
    Minimum requirements for AVCHD/HD editing:
    - Intel Core 2 quad processor with 2.83 GHz (Intel Core i7 recommended)
    - 4 GB RAM
    - DirectX 9.0c compatible graphics card, min. 512 MB graphics card space or more and Pixelshader 2.0 ATI X300 or higher, NVIDIA GeForce 6600 or higher
    - Blu-ray burner to create Blu-ray Discs
    System requirements for 3D playback:
    - Red/cyan glasses required for anaglyph 3D display (included).
    - A special monitor is needed for viewing using polarized filter glasses.
    - A 120 Hz monitor or a projector as well as compatible shutter glasses and graphics card are required for shutter playback.
    Important changes in version 10.0.10.2
    - Bug fix: different transitions did not work correctly between image objects
    - Bug fix: for problems when importing animated GIF.
    Download
    Fileserve
    Trích:
    http://www.fileserve.com/file/EMBqT4n
    http://www.fileserve.com/file/r5sJa7t
    http://www.fileserve.com/file/q2AsNdc
    http://www.fileserve.com/file/SzPv6HW
    http://www.fileserve.com/file/HSn2Qne
    http://www.fileserve.com/file/EYUtgNg
    http://www.fileserve.com/file/2uDbWNd
    http://www.fileserve.com/file/AAXZquT
    http://www.fileserve.com/file/MVxEzfN
    http://www.fileserve.com/file/u9sJsEJ
    or
    Filesonic
    Trích:
    http://www.filesonic.com/file/250485391
    http://www.filesonic.com/file/250492951
    http://www.filesonic.com/file/250492541
    http://www.filesonic.com/file/250484691
    http://www.filesonic.com/file/250487271
    http://www.filesonic.com/file/250484561
    http://www.filesonic.com/file/250481701
    http://www.filesonic.com/file/250481791
    http://www.filesonic.com/file/250468461
