Microcat Ford Europe 12.2010 Multilanguage (2011)
Thảo luận trong 'Phần mềm' bắt đầu bởi sawakara20, 17/1/15.
  1. sawakara20
    sawakara20 New Member
    Microcat Ford Europe 12.2010 Multilanguage (2011) | 5.7 GB
    Electronic parts catalog for Ford European assembly. Provides information on passenger and light commercial vehicles. With the full installation (program data) takes about 4,3 GB. Rolling back the date is not required (working without a rollback to May 2011). Completely reworked the distribution, simply run setup.exe and specify the installation path. Tablets are not required.Whereas previously there were previous versions MICROCAT Ford, do not forget to remove them before installing, otherwise you may experience problems with the definition of the current directory with a database (the program at startup through all logical drives (except for Z:) and look for a folder FEU_DATA, as well as zero-length file in mc1234 root directory).
    Spare Parts Catalog Ford Application Features:
    - Dealer Management System integration - enables order transfer, SOH and Customer search display
    - Positive VIN identification - identifies the correct vehicle and interprets the correct part
    - Easy to use Graphic Index - hyperlinked illustrations of major sections of vehicle to find the part fast
    - Color vehicle images - color images of vehicle lines makes catalog selection easy
    - Superior Search Features
    - Service Part Number
    - Basic Part Number
    - Description
    - Group
    - Motorcraft
    - Illustration number
    - Calibration number
    - Identification number
    - Parts list
    - Cross catalog
    - Built in Ford Video Clips - view Ford information from the video button on the tool bar on illustrations enable the user to select the required part in one click of the mouse
    - Pop up descriptions on illustrations - view part description by just placing mouse pointer over callout
    - Save and recall parts orders - quotations can be saved and retrieved later for ordering
    - OSI Search
    - Save VIN Feature
    - Alpha Index
    - Fast loading illustrations
    - Short cut keys - enabling users to find parts quicker
    - Exceptional operating speed - increases dealership efficiency
    - User notes - adds user notes to parts or sections
    - Manufacturer notes - displays additional information added by the VM
    - Parts pricing - view the latest parts pricing with easy install updates
    - Superior print facility - enabling users to print and fax quotes and images at the click of a mouse
    - Image zooming - enables users to set the illustrations to their preferred size
    - User preferences - users can set Microcat layout, views colours, data display options etc.
    - Double click to order facility - simply double click on callout to order part
    - Workbench - for users to build up an order, for transferring to DMS, printing for quote, or saving for confirmation
    - Linked illustration to data - colored callouts
    Download Filesonic:
    Code:
    http://www.filesonic.com/file/189148171/FE1220.part01.rar
    http://www.filesonic.com/file/189148181/FE1220.part02.rar
    http://www.filesonic.com/file/189148191/FE1220.part03.rar
    http://www.filesonic.com/file/189148201/FE1220.part04.rar
    http://www.filesonic.com/file/189148211/FE1220.part05.rar
    http://www.filesonic.com/file/189148221/FE1220.part06.rar
    http://www.filesonic.com/file/189148231/FE1220.part07.rar
    http://www.filesonic.com/file/189148241/FE1220.part08.rar
    http://www.filesonic.com/file/189148251/FE1220.part09.rar
    http://www.filesonic.com/file/189148261/FE1220.part10.rar
    http://www.filesonic.com/file/189148271/FE1220.part11.rar
    http://www.filesonic.com/file/189148281/FE1220.part12.rar
    http://www.filesonic.com/file/189148291/FE1220.part13.rar
    Link premium: http://www.filesonic.com/premium-ref/394349
    Download Fileserve:
    Code:
    http://www.fileserve.com/file/h3Jr3vP/FE1220.part01.rar
    http://www.fileserve.com/file/9QdH2s9/FE1220.part02.rar
    http://www.fileserve.com/file/d9yeKka/FE1220.part03.rar
    http://www.fileserve.com/file/R9TFYrH/FE1220.part04.rar
    http://www.fileserve.com/file/vMKUGrt/FE1220.part05.rar
    http://www.fileserve.com/file/G73pWUz/FE1220.part06.rar
    http://www.fileserve.com/file/BPtBMeT/FE1220.part07.rar
    http://www.fileserve.com/file/tVGSfYA/FE1220.part08.rar
    http://www.fileserve.com/file/qTDaah4/FE1220.part09.rar
    http://www.fileserve.com/file/dXyQbcD/FE1220.part10.rar
    http://www.fileserve.com/file/ctCPxHy/FE1220.part11.rar
    http://www.fileserve.com/file/rPZH3bX/FE1220.part12.rar
    http://www.fileserve.com/file/hzmE9aN/FE1220.part13.rar
    ! No Password !
    ALL LINKS ARE INTERCHANGABLE
    If you like my thread, please replay to keep topic live.
    Thanks for download.
