TeamPlayer 2.2 + Portable
Thảo luận trong 'Phần mềm' bắt đầu bởi vungochung, 18/1/15.
  1. vungochung
    vungochung New Member
    Trích:
    TeamPlayer 2.2 + Portable | 10.5 Mb
    TeamPlayer allows multiple people to work together on the same computer: Edit and review documents, discuss ideas and get feedback from your audience!
    Inside the TeamPlayer one will find the SandBox;
    The Sandbox is a selection of multi user applications. In each Sandbox 'project' multiple users can work, learn and play together. The SandBox is the first release in a series of true multi-user applications. This feature gives you a glimpse of what multi-user computing is all about!
    Set-up for your first run
    * Connect extra mice and keyboards to your PC.
    * Add a USB hub if you dont have enough USB ports.
    * Download and install the software.
    * Double-click the TeamPlayer icon.
    * Multiple mice will appear.
    * Use the Left Mouse Button to take control
    Home Page - Code:
    http://www.wunderworks.com/teamplayer/
    Download
    Code:
    http://www.fileserve.com/file/nYDr7JY/teamplayer.2.2-MPT_Portable.rar
