Trung Quốc [Tình Cảm] My Beauty Boss 2010 720p HDTV x264-HDCTV
Thảo luận trong 'HD Zone' bắt đầu bởi relex_thu7, 16/1/15.
  1. relex_thu7
    relex_thu7 New Member
    [​IMG]​
    Trích dẫn:Format : Matroska
    File size : 4.36 GiB
    Duration : 1h 34mn
    Overall bit rate : 6 624 Kbps
    Movie name : Encoded By HDCTV Team
    Encoded date : UTC 2011-03-05 07:07:54
    Writing application : mkvmerge v3.3.0 ('Language') built on Mar 24 2010 14:59:24
    Writing library : libebml v0.8.0 + libmatroska v0.9.0
    Video
    Format : AVC
    Format/Info : Advanced Video Codec
    Format profile : [email protected]
    Format settings, CABAC : Yes
    Format settings, ReFrames : 6 frames
    Codec ID : V_MPEG4/ISO/AVC
    Duration : 1h 34mn
    Bit rate : 6 178 Kbps
    Width : 1 280 pixels
    Height : 586 pixels
    Display aspect ratio : 2.2:1
    Frame rate : 25.000 fps
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8 bits
    Scan type : Progressive
    Bits/(Pixel*Frame) : 0.329
    Stream size : 3.98 GiB (91%)
    Writing library : x264 core 114 r1900 60ef1f8
    Encoding settings : cabac=1 / ref=6 / deblock=1:-1:-1 / analyse=0x3:0x133 / me=tesa / subme=10 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=32 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=0 / chroma_qp_offset=-2 / threads=36 / sliced_threads=0 / nr=0 / decimate=0 / interlaced=0 / constrained_intra=0 / bframes=9 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=infinite / keyint_min=25 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=2pass / mbtree=1 / bitrate=6178 / ratetol=1.0 / qcomp=0.60 / qpmin=0 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / aq=2:1.00
    Language : Chinese
    Audio
    Format : AC-3
    Format/Info : Audio Coding 3
    Mode extension : CM (complete main)
    Codec ID : A_AC3
    Duration : 1h 34mn
    Bit rate mode : Constant
    Bit rate : 448 Kbps
    Channel(s) : 6 channels
    Channel positions : Front: L C R, Side: L R, LFE
    Sampling rate : 48.0 KHz
    Bit depth : 16 bits
    Compression mode : Lossy
    Stream size : 302 MiB (7%)
    Language : Chinese
    Trích dẫn:Dựa trên tiểu thuyết cùng tên của nhà văn Trung Quốc Lôi Vũ, bộ phim là câu chuyện tình lãng mạn của anh chàng lập trình viên máy tính Đại Hùng bình thường từ ngoại hình đến gia thế và cô nàng Tiểu Ái xinh đẹp nhưng cá tính, ngổ ngáo. Và điều bất ngờ là sếp mới của anh, Emma lại giống hệt Tiểu Ái. Theo Tiểu Ái thì đó là người chị sinh đôi tính cách khác với mình 1 trời 1 vực. Câu chuyện tình của họ sẽ ra sao? Và Emma, Tiểu Ái thực sự là ai?
    4 Parts 1Gb + 1 Part 369.29Mb + Sub Việt
    http://up.4share.vn/d/6657535757575e5f
